need help with headlights/brake lights
Old Feb 11, 2003 | 04:01 PM
89ROC's Avatar
On my 84TA, there appears to be 3 bulbs in each taillight. When I push the brake pedal, the inner 2 bulbs on each side are lit up, and the outer 1 is lit, but dim.
Now, when the headlights are on, and I push the brake pedal, NOTHING changes. The rear taillights stay light up the same way.
Anyone have any ideas as to what could be wrong?
I think the wrong bulbs could be in the sockets. What are the part numbers supposed to be?
Also, which bulbs are supposed to be illuminated with the headlamps, and which ones for the brake lamps?
Old Feb 12, 2003 | 11:38 AM
89ROC's Avatar
Anyone..... ?
Old Feb 12, 2003 | 11:03 PM
Dans_Zed's Avatar
Car: 85 Z28
Engine: 383
Transmission: TH350
Axle/Gears: 3.73 posi
1156 single filament, is one intensity, and has a single contact on the bottom of the bulb.
1157 (or 2057) is double filament, is two intensities, and has two contacts on the bottom of the bulb.
If you interchange bulbs in sockets where thay do not belong you can get similar results as you did.
If a problem persists, check condition of your ground wires for the rear lighting circuit and make sure that there is no corrosion inside the light sockets.
good luck
Old Feb 13, 2003 | 09:59 AM
89ROC's Avatar
good luck
cool thanks, but where does each bulb go?
Old Feb 13, 2003 | 12:03 PM
Dans_Zed's Avatar
Car: 85 Z28
Engine: 383
Transmission: TH350
1157 (or 2057) = Parking and brake lights = outer most lights
1156 = Parking lights or reverse only = located towards the center of your tailights
TrevinE
Sep 14, 2015 03:20 PM
florida_gators
Exterior Parts Wanted
Sep 7, 2015 07:19 PM
flash2042
Interior Parts Wanted
Sep 7, 2015 07:15 PM
luvofjah
Sep 3, 2015 07:08 PM
