Replacing a steering column......
Old Feb 15, 2003 | 09:08 AM
War_Eagle's Avatar
Has anyone replaced the tilt steering column on there third gen? If so, what was involved and how much of a job is it? I am thinking about doing the job myself and just need some advise. Thanks for the help......
1986 Trans Am stock (for now)
305 c.i.d.
automatic trans
Old Feb 15, 2003 | 02:26 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
-Remove the underdash trim to expose the coulmn bracing.
-Remove the bolt holding the intermediate (sp?) shaft to the column under the hood (at the firewall).
-Remove the 3 hex screws at the base of the column at the firewall (inside car).
-Remove the 2 nuts holding the column to the bracing under the dash.
-Lower column and unplug all wiring.
-Pull column out.
-Installation is reverse of removal.
Can be completed w/in an hour if you're motivated.
Old Feb 15, 2003 | 08:34 PM
War_Eagle's Avatar
Thanks for the reply. I believe I can do that. The local salvage yard has a nice tilt column with the steering wheel for $125, I will be picking it up on Monday. Again thanks for the info......
305 c.i.d. engine
700R4 automatic transmission
Old Feb 15, 2003 | 10:44 PM
deadbird's Avatar
Engine: TPI 305/ v6
I'm assuming you're talking about a yard that has the parts pre-pulled or does it for you for $125
I've put 2 in my old camaro (original one pre-broke, 2nd, my-bad) and I paid $15 for one (pull it yourself) and $30 for the other with matching delay wiper motor. I'd hate to see anyone pay $125 to pull it themselves. Even with no (to the pull a part), I'd try to haggle a little ($25 maybe).. it is from a junkyard afterall.
Either way, it is a fairly easy DIY project that can be done w/o special tools and is cheaper than having someone else do it for you.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
Fronzizzle
Mar 18, 2019 08:29 PM
backtothe80s
Sep 5, 2015 12:39 AM
Keiffer76
Car Audio
Aug 9, 2015 11:37 PM
