GM Part #14093107...what is this???
Old Feb 23, 2003 | 02:05 PM
metalhead212121's Avatar
Car: 91 Firebird Formula
Engine: For me to know.....
Transmission: and you to find out....
Ok..I know this is a relay but what kinda relay is this??? I went to GMpartsdirect and all they say is that its a relay... We have such "winners" at GM. :lala: :lala: :lala: :lala:
Dan
Old Feb 25, 2003 | 09:50 PM
black89ws6's Avatar
Car: 89 Formula, WS6
Engine: LB9/peanut cam :(
If it's the relay I'm thinking of, it's kind of a multi-purpose relay. From 88 (i think) on, they used one type of relay for almost everything. I've got like 6 of this one type of relay in my 89 firebird. 2 for cooling fans, one for the MAF power, one for the MAF burnoff, and 2 others for *** knows what else.
If it wasn't so cold where I'm at right now, I'd go outside and look at the number on one of those relays to find out.
Where did you come up with that part number? Usually it's the other way around...you know what you're looking for, and then you get the PN.
Old Feb 26, 2003 | 05:49 PM
I think this will answer your question...[URL=https://www.thirdgen.org/techbb2/showthread.php?s=&postid=1167095#post1167095#post1167095]
Dan
Old Feb 26, 2003 | 06:13 PM
black89ws6's Avatar
If that part number is correct, then that relay is the starter enable relay. It's inside the driver's side kick panel. When the VATS receives the proper key resistance, then it activates that relay which enables the starter.
LT1Formula
20
Nov 14, 2015 12:02 AM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
Fronzizzle
Aug 9, 2015 01:15 PM
1nastygta
Aug 8, 2015 07:38 PM
