TPI to carb. Hooking up Dist wires?
Old Mar 6, 2003 | 08:32 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
Ok, I am changing from a 92 TPI to carb. I am using a non-computer controled dist. Which wires do I need to use to hook up the Dist. Is it the Two wires going to the gray or black plug on the TPI coil?
Old Mar 6, 2003 | 07:52 PM
nicksL98's Avatar
not overly sure on the 90-92 cars but on 87 there was s coil connector with one pink and one white wire. pink is 12V inginiton and white is for tach .
Old Mar 7, 2003 | 08:03 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
Yeah, I had posted it on the TPI board and got the same answer.
Thanks.
1989formula5.7l
Aug 17, 2015 02:56 PM
tero
Aug 15, 2015 02:47 PM
stalkier
Aug 13, 2015 12:59 PM
Sanjay
Aug 12, 2015 03:41 PM
stalkier
Aug 7, 2015 04:49 AM
