ALDL Wiring
Old Mar 7, 2003 | 06:15 PM
conlinj's Avatar
ALDL Wiring
Ok i am new to posting on this board but have been using it for the past year to help with my camaro, you guys have unknowling helped fix alot of my problems. I'm glad that the search is back up Now I have a 1986 5.0L tpi automatic, that the previous owner at some point removed the wiring from the car. The aldl terminal was not from a camaro and some wires were not hooked up. I have replaced the terminal with a camaro one and there is no connection for the "M" slot on the aldl. The wire from the donor car was tan. I looked in the harness and there are no more open wires. I saw on a diagram in this site that it is the 8192 Serial Data Output +5vdc, I have looked at wiring diagrams and can't find this wire anywhere. Where does it come from so I can hook it back up. I bought the car before it was takin to the junkyard and know it's road worthy again, just trying to fix the little things. Thanks for your help in advance. -Jim
Old Mar 7, 2003 | 08:58 PM
conlinj's Avatar
The connecter i got from the 1991(2) is like this:
a-blk/whte stripe
b-whte/blk stripe
c-gray solid
d-empty
e-orange solid
f-tan/blk stripe
g-empty
h-empty
j-empty
k-brown solid
l-empty
m-tan solid
The connector on the car was:
a-blk/whte stripe
b-whte/blk strpie
c-gray
d-whte solid
e-empty
f-tan/blk stripe
g-m all missing retainer gone
The wires from the dash harness are:
blk/whte stripe-ground
white/blk stripe-ecm diagnostic request
gray solid-?
orange solid-fuel pump
tan/blk stripe-tcc
I don't know if the gray wire is for the data output or the ses light ground or neither, am i missing any wires?
chazman
Aug 28, 2018 03:25 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
mike_c
Aug 27, 2015 04:32 PM
Bryan F
Aug 27, 2015 07:28 AM
chazman
Aug 22, 2015 02:01 PM
