headlights go off
Old Mar 14, 2003 | 10:53 PM
losthog's Avatar
headlights go off
driving down the road and my headlights went out, dash and parking lights still on, everything working ok but headlights, they came back on after about 45 sec. is there a relay or a time fuse?
1983 z/28.
Old Mar 15, 2003 | 05:02 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
It's the circuit breaker inside the headlight switch itself; it's overheating from too much current running through it, and 'kicked out'. Once it cooled down, it reset itself.
If you've recently switched to a higher-output headlight, those could be the culprits, as could any corrosion or dirt on the connector contacts of the headlights.
A great solution to the problem of higher-output lights can be found here.
Pete
Old Mar 17, 2003 | 03:58 PM
losthog's Avatar
thanks pete I did put in new cool blue headlights, and I read the site you gave. guss I will have to go back to the old lights or build a new harness.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
