Headlights Please help????
Old Mar 16, 2003 | 01:09 PM
Rule69's Avatar
Car: 1986 Camaro
Engine: 305 for now
I just replaces the high and low beams when i turned the lows on they worked fine but when i turned the highs on the drives side low went out. Please help..
Old Mar 16, 2003 | 01:25 PM
Berlinetta00's Avatar
Veteran: Marine Corp
Car: '84 Berlinetta
Engine: ZZ4
Transmission: BTOD stage 3
Axle/Gears: 3.23 posi disc
Recheck the lamp numbers. If you put in the wrong kind of lamp, it could cause a problem like the one you described. You should have a 3 prong connector for the driving lamps and a 2 prong connector for the high beams (I think).
Another thing is to check all your connections, make sure nothing has corroded or come loose since the replacement.
-Berlinetta00-
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
