Thanx to the members of this board
Old Mar 15, 2003 | 10:26 PM
Dragons91RS's Avatar
Car: 91 Camaro RS
Engine: 305 LO3
Transmission: 700-R4
Thanx to the members of this board and info they have supplyed other members in the past I was able to figure out my electrical prob. none of the interior electrical components worked in my car sice I got it. Ive driven my self mad over the past 2 months trying to figure out why my trunk release,power mirriors,powerlocks, all interior lights, and horn didnt work. I thought it was a wiring problem, comes out it was just the damn acc fuse, but I didnt think to check the for a blown fuse with so many things not working
Now if I could just figure out how to rewire my third break light in the hatch window all eletronics in my car will work! any one able to tell me how to rewire it?
Old Mar 16, 2003 | 01:36 PM
Berlinetta00's Avatar
Veteran: Marine Corp
Car: '84 Berlinetta
Engine: ZZ4
Transmission: BTOD stage 3
Axle/Gears: 3.23 posi disc
Obtain a wiring dagram for your vechicle. It will tell you which wires you need to tap into to get the right results. I'd think (although I don't have one) that you would have three connections to make, one for the ground, one for the brake power switch (located on the brake pedal hardware, it is the pressure switch that come on when brake is depressed), and another for the dim when the lights are on (I guess it might not need this wire, because it is only for braking, but a dim could be on there anyways)
Hope this helps out,
-Berlinetta00-
LT1Formula
Oct 8, 2015 08:34 PM
PAFORM350
Wheels and Tires
Oct 2, 2015 07:21 PM
Linson
Oct 1, 2015 09:50 PM
zman1969
Oct 1, 2015 11:09 AM
