Oxygen sensor???
Old Mar 16, 2003 | 06:48 PM
Ericf105's Avatar
Oxygen sensor???
Can anyone tell me where the Oxygen sensor plugs in?
I have an 1989 Iroc with a 350.
The guy who built my car ripped off the O2 sensor when he put on the custom exhaust.
Now the car isn't running so good....(go figure).....
If you have a picture of where it plugs in, it would great.
Old Mar 16, 2003 | 09:10 PM
MdFormula350's Avatar
what kinda headers does this custom exhaust have? it should have a o2 sensor bung somewhere on it..
unless you might have to weld a bung and then add in a o2 sensor..
Old Mar 16, 2003 | 09:21 PM
Ericf105's Avatar
It still has factory Exhaust manifolds, but everything from there back is custom.
I know I will have to weld a O2 sensor fitting in, but that's not my main problem.
I don't know where the O2 senor wire plugs in......
Old Mar 17, 2003 | 05:22 PM
25THRSS's Avatar
If it still has the factory exhaust manifolds then you dont need to weld in anything, the bung is in the manifolds on the front drivers side where the collector is. Check and see if it's still plugged in, if it is then thats not the problem, its something else.
Old Mar 17, 2003 | 08:07 PM
Ericf105's Avatar
No I guess when I said factory I miss spoke , the guy that built my car pretty much through it togerther.
It's a mess the exsauhst manifolds that are on there are not from an IROC ....well not a 89 any way.
This car has been buchered!
I have a 88 Trans am with a 305 can anyone tell me if the O2 sensor would plug in , in the same place ?
Old Mar 17, 2003 | 08:11 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
The manifolds on pretty much any f-body I've come across that still has a motor, the 02 sensor is on the drivers side (even headers have the o2 on this side). The o2 faces the front of the engine bay and is right above where the y-pipe meets the manifold 'collector'. It's not always easy to see with all the crap in the way.
Old Mar 17, 2003 | 09:09 PM
25THRSS's Avatar
I agree with deadbird, if it has any of the exhaust manifolds from a fuel injected third gen then it has the o2 sensor in the front drivers side manifold. If its already in place then you have other problems besides that. Just go look and let us know if its there or not.
HoosierinWA
Oct 7, 2015 10:15 AM
aaron7
Sep 30, 2015 09:15 AM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
dusterbd
Sep 29, 2015 08:40 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
