No tach after Mallory ignition install
Old Mar 24, 2003 | 12:53 AM
RSFreak's Avatar
Car: 1985 Camaro, 1986 Trans Am
Engine: 5.0L carbed and 5.0L TPI
Transmission: TH700R4
Axle/Gears: 3.23 and 3.27 posi
I just installed a Mallory HyFire VI-A capacitive discharge ignition on my '91 RS. It works great, but now my tachometer doesn't work. Anyone know where I can locate or how to identify my tachometer lead?
Old Mar 24, 2003 | 10:02 PM
Odyssey's Avatar
It's the white wire on your ignition coil harness. Hook that up to the tach output of your Mallory ignition box.
Old Mar 25, 2003 | 04:52 PM
RSFreak's Avatar
Cool! Thanks, I thought that might be it, but I didn't want to 'experiment' and blow something up!
Old Mar 25, 2003 | 07:49 PM
RSFreak's Avatar
Doh! That didn't work. Any other suggestions?
Old Mar 26, 2003 | 02:27 AM
1fastgta's Avatar
Car: 91 GTA
MSD makes at "tach adapt" coil. When I put my MSD 6A on, the tach worked unless I floored it, then the needle would drop to zero. After the tach adapt was put in, I haven't had any problems, and that's been 3 years now.
Old Mar 26, 2003 | 02:31 AM
RSFreak's Avatar
Yeah, the Mallory instructions said I might need one of those (though I didn't need one with the MSD-6A on my '85 Z), but my tach doesn't work at all.
Old Apr 14, 2003 | 11:40 PM
jloshotz's Avatar
Car: 1991 Z/28
Engine: 5.7 TPI
These Tachs seem to be very intolerant to any types of primary ignition mods. I only put in an accel super coil in my 91 5.7 L Z, and the tach hasn't worked right since. I am currently looking into the location of a factory installed inline tach filter which i believe to be the culprit...
~Jack~
theurge
Aug 21, 2015 12:46 PM
mustangman65_79
Aug 7, 2015 09:41 PM
stalkier
Aug 7, 2015 04:49 AM
