Is it safe to replace a fusiblellink with a fuse?
Old Mar 24, 2003 | 12:40 PM
Mikes86SC's Avatar
Car: 1986 IROC-Z
Engine: 5.0 TPI
Is it safe to replace a fusible link with a fuse?
A while back I determined my alternator was overcharging because the fusible link in the voltage sensing wire was blown. I replaced it with a 20A fuse in a weather proof case. Is this safe, or should I install another fusible link? If so, what rating as I forgot the rating of the one I took out.
Old Mar 25, 2003 | 06:58 AM
Mikes86SC's Avatar
Car: 1986 IROC-Z
Engine: 5.0 TPI
Anyone?
Old Mar 26, 2003 | 04:31 PM
Mikes86SC's Avatar
Car: 1986 IROC-Z
Engine: 5.0 TPI
Old Mar 27, 2003 | 05:35 AM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
It is perfectly fine to use a fuse. The difference primarily between fuses and links is that links are generally used in circuits that are either hard to get to or that normally carry high current. Fuses depending on thier size can run hot and melt when carrying high current for extended periods of time. Links can be purchased at any decent parts supplier. My diagrams show the sense wire going to the fuse panel under the dash.
BRoss99
Aug 10, 2025 05:08 PM
Ghettobird52
Jul 5, 2024 11:18 PM
RazorN8
Jan 7, 2022 11:44 AM
justin57
Aug 20, 2015 07:05 PM
Keiffer76
Car Audio
Aug 9, 2015 11:37 PM
