Dual Fan wiring question
Old Mar 24, 2003 | 01:51 PM
vwdave's Avatar
I just converted from Single to Dual fans. I bridged the two required connectors from the single connector. Someone told me after I did it I was going to melt that section of the harness and the fan switch. Is this true? If so, what do I need to do to prevent it? PN's would be great, diagram will be fantastic.
TIA.
Old Mar 24, 2003 | 08:01 PM
jwfirebird's Avatar
Car: 87 bird
Engine: enough to break stuff
Transmission: manual th400
Axle/Gears: 4.10
i dont think it will melt, my wifes grand prix has two fans and uses the same size wire as the one on my firebird.
as long as you have a fuse(or the stock fuseable link)in place in between the power source and the fans there is no way for it to draw too much current.
if you have a fuse and start blowing them then you can wire it with a relay and fuse to divide the current.
Old Mar 24, 2003 | 08:22 PM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
It will melt, the stock fan was designed to run one fan since it has one relay. Adding a second fan to the same wiring and relay will overload it quickly, especially the relay.
Old Mar 24, 2003 | 09:25 PM
vwdave's Avatar
Ok, any websites that cover this? I dont want my car to melt.
BTW, I hate wiring with all my heart and soul. Everytime I do it, something messes up.
eightsixseven
Dec 16, 2024 01:50 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
redmaroz
Aug 16, 2015 11:40 PM
Leggman1
Aug 6, 2015 04:15 AM
