No start, no fuel, electric problem
Old Apr 5, 2003 | 03:28 PM
ops32's Avatar
Car: 1983 25th Anny Daytona 500 T/A
Engine: Stock...inoperative... 305
Transmission: Automatic
My tale of woe...
Last fall while driving the car ('83 pace car) it died and would not restart. Had it towed home. Initial troubleshooting told me I had an electrical problem because I could *see* the injectors squirting fuel (CFI) and the engine turned over easily, but would not start. I let it sit over the winter. Started troubleshooting last month and found out the coil checked bad. Replaced coil and when I tried to start it, it would turn over easily, but now I'm not getting any fuel out of the injectors. Replaced the ignition module today with same results. Also noticed today that the engine dash instrument guage needles move, but I'm not getting any idiot lights at all. Fuel pump works (can hear it) and I get fuel out of the tubing at the injectors.
So... no idiot lights, and no input to the injectors... Are these related? Anybody have any idea what to check next? Can I troubleshoot the computer, or is that beyond the realm of a driveway mechanic? I've looked thru about four different manuals and they aren't much help...
Thanks,
Rob
Old Apr 5, 2003 | 04:00 PM
Vader's Avatar
Ops-Three-2,
Are you getting any ignition? Does the tach move when the engine is cranked?
Old Apr 7, 2003 | 10:01 AM
ops32's Avatar
Originally posted by Vader
Ops-Three-2,
I'll check tonite after work...
Thanks,
Rob
Old Apr 8, 2003 | 12:38 AM
mrt89rs's Avatar
From: Tucson AZ where the 3k ft of elevation kills your time
Car: 89 camaro rs
Engine: 383 .06 over
Transmission: th350
Axle/Gears: 3.73 10 bolt
have you checked all your fuses?
Old Apr 9, 2003 | 12:10 PM
jcampbelljac_88's Avatar
Car: 92 camaro RS
Engine: 305 TBI
Look and see if there is a fuse by your battery usally about a 20 amp in a little black relay looking box. If if blows it will stop you from getting any fuel and diagnostics port will not work if this fuse is blowing.
Old Apr 9, 2003 | 06:30 PM
theratdude64's Avatar
Car: 95 Z28
Transmission: Built 4L60E with 3000 Stall
Axle/Gears: 3.23? I'm not sure
That might be my problem!!!!!! you may have saved my car. when I try to crank the engine, the tach goes up, but the car cranks easy, and I replaced the ECM, PROM, and ignition Module. Its TBI, and I cant see the fuel squirt into the injectors. Would that help it?
THANK YOU SOO MUCH IF IT DID!
Haha, it edited G O D lol:hail:
Old Apr 10, 2003 | 08:12 AM
ops32's Avatar
Cool. I'll look for that!
Rob
92camaroJoe
Jul 29, 2023 07:57 PM
justin57
Aug 20, 2015 07:05 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Tony Ferrarri
Aug 11, 2015 07:59 PM
