Need speedo help
Old Apr 15, 2003 | 01:45 AM
osmonson's Avatar
Need speedo help
I have a 92' RS 5.0 TBI. My speedo reads 35-40mph at 25mph, 50 at 35, 80 at 55, etc. It hits 110 (and governs) when I'm only doing 75. The VSS has been replaced with no change, and the computer reads the same as the speedo. What do I do next?
Old Apr 15, 2003 | 01:02 PM
dd85T/A's Avatar
Car: 85 T/A
Is everything stock? Did it work at some point? If its stock then its the sender, buffer box or the spdo itself I think. If the rearend, tire size, transmission ect. changed thats a different story. You will need the correct spdo gears or a box to change the signal.
Old Apr 15, 2003 | 06:28 PM
Dave Y's Avatar
Car: 04 Xtreme Blazer
Engine: 4.3L V6
soumds like my IROC, I went from 2,72 rear gears to 3.73, and the speedo reads about like yours
Old Apr 16, 2003 | 08:56 PM
osmonson's Avatar
I think everything is stock. I have only had the car a couple of years though, and it hasn't worked. Is there anyway to test the buffer?
Old Apr 17, 2003 | 06:32 AM
dd85T/A's Avatar
Car: 85 T/A
Just pick one up from a junk yard or from Hawks. Should only be a few bucks.
GTAman
Jul 3, 2024 07:29 PM
Elephantismo
Feb 13, 2019 12:51 AM
Nervous2
Oct 8, 2015 10:53 PM
rs_z28_vert
Sep 30, 2015 09:47 PM
TrevinE
Sep 14, 2015 03:20 PM
