headlight wire harness and h4s (I need help)!!!!
Old Apr 20, 2003 | 08:47 PM
jcurrieirocz's Avatar
Car: '81 Trans Am
Engine: 6.6L
Transmission: auto 350
I had great working lights till i installed my h4 conversion (low beams) but cause they tech run hi and low. Ok my problem is that only after i have my switch in the hi beam position for a while they start to flicker and trip the breakers i assume. I know that most of you made your one harness but I dont think I want to make my own right now but I do want to fix the flicering problem buy adding a relay I bought. I was told I only needed one relay. and I should only need one right? Witch one in theis pic should I add the relay I have to cure my low beam (hi/low) lights from flicker while there in the hi mode.
Old Apr 20, 2003 | 09:16 PM
Car: '81 Trans Am
Engine: 6.6L
ok i think ill add it to the green (high beam) wire. Do you think Ill still have problems with just adding one relay on the high circut??
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
TheJoeY88
Dec 31, 2016 07:30 PM
stalkier
Dec 6, 2015 11:25 PM
g.l.mos
Aug 22, 2015 12:02 AM
stalkier
Aug 21, 2015 01:54 AM
