Push-button starting??
Car: '84 Berlinetta
Engine: ZZ4
Transmission: BTOD stage 3
Axle/Gears: 3.23 posi disc
Anyone ever wire up a push-button starter for chevys? The reason I ask is the wiring in my blazer is all screwed up, espacially the ignition. Can I just put a 10 or 8 gauge wire from one postitive terminal (it is a dual battery set-up) to a push button, then to the "S" terminal on the starter?
I already figured out how to use a "run" switch instead of the stock ignition on the diesel, but the starter is what is bugging me. Right now, I have to jump a hot wire directly to the wire coming off of the "R" terminal on the starter, and when I do the starter keeps turning until I disconnect the main power. I really need some help on this one. The starter leads are the same as a 350 starter, with the standard hot, run and start terminals.
Car: 1989 IROC
Engine: 5.7 / 350 cuid
Yeah, you got it right, we did the same sort of setup on my buddies 79 Z28. Run the wires like you said and just get a push a 30amp push button from an auto store. The push button should keep you from having the problem with the starter continuing to run.
The_Phoenix
Feb 4, 2016 07:10 AM
92camaroJoe
Aug 13, 2015 06:07 AM
