what wiring
Old Apr 30, 2003 | 08:26 PM
2birds40's Avatar
what wiring
ok i have a 85 firebird with a 2.8mpi i am putting in a carbed 350 what wires from the 2.8 do i need to keep i want it to look real clean when finished
Old May 1, 2003 | 12:37 AM
2birds40's Avatar
can anyone help with this by the way it is a 85 firbird no smog or ac just the basics please help i want to get started real soon
Old May 1, 2003 | 01:05 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
You need (most) all the wires from the bulkhead (for lights, coil gauges, etc). All the wiring from the pass side fender by the heater box is ECMand worthless to a carb'd engine, throw it away.
You can also try doing a search looking for "TPI or TBI to carb swap". You should come up with quite a bit of useful info by doing that.
Old May 1, 2003 | 01:23 PM
MikeS's Avatar
Another way to do it is to go ahead and do the swap, then worry about cleaning out unused wires. You'll want to leave anything running to the starter. Also, you'll want to keep a switched 12 volt power supply for the distributor and an electric choke (if you will be using one). When I did mine, I installed the engine and used what wires I needed to get it running. Once I knew everything was ok, I worked on eliminating and cleaning up what wasn't needed
Deadbird's suggestion sounds right on to me. All that stuff that goes behind the passenger side fender to get around the firewall and then enters the passenger compartment behind the kick panel is ECM. I ended up cleaning those up one by one, since I had used one as a power source. Guess that's one problem with my method, huh?
Old May 1, 2003 | 04:02 PM
2birds40's Avatar
hay thanks guys so nothing that runs to the ecm is needed i thought that i read somthing about needing the fuel pump wiring or something i want to get it all out before i do the swap becouse i am painting the engine bay and don't want to have to mess with any thing not needed thanks guys
Old May 1, 2003 | 09:39 PM
MikeS's Avatar
Hmmm, I didn't think about the fuel pump. I used a mechanical pump. If I'm reading my wiring diagram right, the fuel pump relay does interface with the ECM. Maybe somebody can verify?
Glowsock
Jan 9, 2017 04:06 PM
Caspar
Jun 19, 2016 11:19 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Bryan F
Aug 27, 2015 07:28 AM
Bert87
Aug 23, 2015 03:50 PM
