electrical testing
Old May 2, 2003 | 07:31 PM
warrior_91's Avatar
Car: 86 T/A
Transmission: 700-R4 Auto
electrical testing
Im having trouble with many things such as fog lights, headlights, headlight motors, and the horn. But can I use that thing under my dash and will it dish out electrical codes? If not, what type of testing do I have to do to figure out whats wrong with my wiring to all of the components Ive listed?
Old May 2, 2003 | 10:03 PM
Steves91z's Avatar
First, if it all possible get your hands on a wiring diagram.
The first thing I noticed from your post is that all of your problems seem to come from front end lighting. All of this is probably on a common harness. See is there are any obvious signs of problems with that wiring harness. Look for attempted repairs or someone splicing into the harness. But the easiest way to diagnose the problem is with a wiring diagram. Write down everything that is not working. Start tracing each item back to the alternator, you will likely find that everything having a problem travels through a common fusable link, horn relay, wiring harness connector, or some other common point. This will point you to the problem area.
Steve
Hotrodboba400
Dec 10, 2019 07:07 PM
gta892000
Aug 11, 2019 11:16 AM
Grant2k
Apr 4, 2016 08:21 AM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
