Dash light problem on 86 Berlinetta
Car: 86 Berlinetta.
Problem:
The dash lights work until I turn on the headlights. Once the headlights are turned on all the lights in the dash go out. Does anyone know what the problem might be?? I've tested all the fuses, wires, lights and I've checked the dimmer switch.
Problem:
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: Dash light problem on 86 Berlinetta
About 90% of the time that problem is caused by a bad Dimmer circuit in the Light Module.
About 9% of the time the Dimmer Rheostat control is not making contact with - or there is damage to - the circuit board.
About 1% of the time the Rheostat is not adjusted properly !! ( turned down to low )
Car: 1985 berlinetta
Engine: 305 carbureted
Transmission: 5 speed from a '97 trans am
i want to know the same thing. where can i find a light control module?
if i cant find one easy im just going to make my own gauge cluster with autometer gauges, that should work right?
The light control module is no longer made by GM/ACDELCO. You will have to either get a used one from the junk yard or ebay or pull the light control module and have it rebuilt. I just pulled mine today and I am shipping it out tomorrow to have it rebuilt for $150. My light module just died and my hazards wont stop flashing, the blinkers stopped working, the interior lights won't turn off and the head lights won't turn on lol.
