I need to know where the horn relay is located in my 86 trans am because my horn dont work.
Its in the convience center, under the dash, near the ALDL connector. You'll have to take the lower dash panel off. It is a flip down unit. The turnsignal/hazard flasher and door buzzer is there too. Put the turn signals on and follow the noise. Use a chiltons or haynes manual to see which relay it is.
Matt
Matt
