Two "L" shaped brackets with MSD GM Coil?
Old May 16, 2003 | 06:40 AM
MX265
Guest
Posts: n/a
Two "L" shaped brackets with MSD GM Coil (part#MSD-8226)? Do these serve a purpose? I thought the coil would just mount to the original coil bracket once I drilled out those pesky rivets. The manual says to install coil using the supplied hardware, and that is the extent of the instructions. Do I need these "L" shaped brackets for some unforeseen reason? Any input is appreciated.
Thanks,
Andy
Old May 17, 2003 | 07:22 PM
Frik92RS's Avatar
Car: Camaro RS
Engine: L03 305
Transmission: 700R4 Auto
You don't need them. It'll install just like the stock one with those long bolts once you've drilled out the rivets.
Old May 22, 2003 | 07:49 PM
Twilightoptics's Avatar
Car: '87 IROC-Z/'82 RX7
Engine: SBC 355/1.1L Rotary
Transmission: T56/5 Speed
Axle/Gears: 4.33/3.93
I didn't use them. I just mounted mine like stock, works fine after 20k miles.
9192camaro
16
Feb 3, 2019 12:21 AM
stalkier
Dec 6, 2015 11:25 PM
Genopsyde
Nov 11, 2015 10:46 PM
toronto formula
Nov 10, 2015 06:17 AM
midias
Aug 15, 2015 05:07 PM
