Everyone with H4 lights and wired in relays, come in please!!!
Old May 19, 2003 | 04:47 PM
jcurrieirocz's Avatar
Car: '81 Trans Am
Engine: 6.6L
Transmission: auto 350
I just wired in my relay to my hibeam circut so my lights would run the hole time without flickering and shuting off. I seemed to got it wired all up and it works great they dont fliker or shut off. BUT the factory wires i knoticed were getting really warm and the wires i put in are getting pretty warm too almost too hot... its makeing me concered. Is there any chance those wires will cause a fire or get too hot??? I got the proper relay and fuse and its hooked up all right i bubble cheacked. Anyone else knowticed how warm the power wire and wire going to the lights gets???
Jeff
Old May 19, 2003 | 05:22 PM
meridius's Avatar
Car: 1988 Trans Am GTA
Engine: 5.7 TPI (Now HSR)
Transmission: 700R4 by Probuilt
Axle/Gears: 3:27 9 Bolt Posi W/ Discs
exactly what power wire did you run off the headlight wire? you use that as the switching wire and the main power wire should be a constant hot battery source that can handle some power since H4s need alot more of it.
Old May 19, 2003 | 06:16 PM
Car: '81 Trans Am
Engine: 6.6L
yes thats what i did........heres a breakdown of whats getting hot going into or comeing out of the relay.
[norm temp]- wire from car (switched factory) going into relay
[norm temp]- ground for relay
[hot to warm]- wire going to headlights from relay
[hot to warm]- wire going from batt. to relay
[hot to warm]- relay itself
I feel the wire is definetly hot and noticable after having the highs on for atleast a few good mins. Does anyone feel heat coming from there wires or relay???
Old May 19, 2003 | 08:25 PM
meridius's Avatar
well seeing as how its pulling a decent amount of current throuh it its going to get a little warm but it shouldnt be getting so hot you cant touch it or hot enough to melt itself down.
Old May 20, 2003 | 09:45 PM
Car: '81 Trans Am
Engine: 6.6L
so you have them how warm does yours get... or anyone elses?
Thanx
BRoss99
Aug 10, 2025 05:08 PM
eightsixseven
Dec 16, 2024 01:50 PM
RazorN8
Jan 7, 2022 11:44 AM
Caspar
Jun 19, 2016 11:19 PM
Omega
Aug 10, 2015 12:46 PM
