Headlight doors don't open
Old May 31, 2003 | 10:46 AM
anagodadavida's Avatar
It's an '86. All three relays are working properly but there is no current to terminal A on either actuator relay -- hence, no power to either motor on the "open" circuit.
It's the red and white fusible link wires that run to fusible links E and D (according to the schematic). Where do these wires go? Where are these fusible links located?
Old May 31, 2003 | 11:30 AM
Vader's Avatar
If you jumper a fuse 12VDC battery source to the relays, do the doors operate?
My schematics shoe a "C" and "D" fusible link, but regardless, the links should be in the battery positive cable connection from the starter. There is a single wire connector near the firewall at the right rear of the engine with a red wire - that's one of the links. Inspect the connector as well - they are not the best design.
Old Jul 1, 2003 | 11:45 AM
I finally took the time to trace these two red & white wires down to the source of the problem. They are routed along the driver's side in a harness that runs along the frame rail. I had checked this harness before but only found a wide gauge red wire along with some others.
This time, I pulled the wires out of the plastic tubing and found the fusible link wires. They were about six inches to a foot behind the battery. The red & white wires were crimped to the pink fusible link wires. The two fusible links were crimped to the wide red wire. I have twelve volts at the red wire but none at the other side of the fusible links. I've never seen this before.
I just wonder what caused them to blow.
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
BlueIroc-Z
Jun 9, 2019 03:22 AM
BlackTopKing
Aug 19, 2015 12:13 PM
89lsc
Aug 14, 2015 04:58 PM
