Brake Lights Driving Me Nuts!!!!!!!!!
Old Jun 30, 2003 | 01:14 PM
rik89gta's Avatar
Car: 89 FORMULA 350
Engine: 5.7 L98
Axle/Gears: 9 BOLT/ 3.27 GEARS
OK, MY BRAKE LIGHTS WENT OUT. I CHECKED THE BULBS AND WIRING IN THE BACK AND ALL SEEMS GOOD. MY NEXT IDEA WAS TO REPLACE THE BRAKE LIGHT SWITCH. I INSTALLED IT AND I STILL HAD NO BRAKE LIGHTS. THEN I LOOKED AT THE FUSE BOX AND NOTICED THAT THERE WAS A 20 AMP FUSE MISSING IN THE HAZ/LIGHTS SPOT. I PUT A FUSE IN AND NOW ALL THREE OF MY BRAKE LIGHTS STAY LIT WHEN I'M NOT EVEN HITTING THE BRAKES.WHEN I HIT THE BRAKES THE BRAKE LIGHTS GO OFF. WHAT IS GOING ON? THIS IS DRIVING ME CRAZY!!!! ANY HELP WOULD BE GREATLY APPRECIATED.
Old Jun 30, 2003 | 02:24 PM
ChaosRanger's Avatar
Car: 1984 F41 T-Top
Transmission: 5 speed
Not a tech ...
Not 100% sure but check your brake switch to see if you didn't put the wire(s) on backwards.
Oh ... watch how you type on the forum boards, all caps mean you are YELLING or EXPRESING something. All caps through out the whole posting is hard to read.
Old Jun 30, 2003 | 02:27 PM
RPM WOT L 98's Avatar
Yeah it definitely sounds like reversed wiring.
Old Jun 30, 2003 | 05:21 PM
rik89gta's Avatar
Car: 89 FORMULA 350
Engine: 5.7 L98
Thanks for the info. I will check it out.
Old Jul 1, 2003 | 12:25 PM
rik89gta's Avatar
Car: 89 FORMULA 350
Engine: 5.7 L98
Yep, I plugged the small two prong connector in backwards. The brake lights work fine now. It feels good to drive my GTA again. Thanks a bunch guys!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
stalkier
Aug 13, 2015 12:59 PM
Omega
Aug 10, 2015 12:46 PM
mustangman65_79
Aug 8, 2015 12:07 PM
