fuse in 82 third from left side and third column over
Old Jun 9, 2003 | 12:26 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
delete
thanks
Old Jun 10, 2003 | 12:36 PM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
ttt, hoping someone can look on their 82-84 fusepanel and see, maybe if someone is parting one such car out or happens to be under the dash of one for some reason ?
thanks
Old Jun 10, 2003 | 02:55 PM
Jproz1167's Avatar
Car: 1982 Trans Am & 1982 Corvette
Engine: L-98 with LO-3 induction. 350 CFI
Transmission: 5 speed and vette has 700r4
Axle/Gears: 373's in T/A .. vette unknown
fast68
this is a 82 LG-4
top
10 10 20 20
{ecm ign} {F. pump} {stop/haz} {choke}
20 20 25
{turn B/U} { blank } { tail } {htr A/C}
10 20
{gauges} { blank } {courtesy } {circuit breaker}
5 10
{ign} {inst.lamps} {radio} {bat} {circuit breaker}
25
{ign}{ign} {wiper} {bat}{bat} {blank}
bottom
courtesy is for the dome lights/ cig lighter stuff like that
hope that helps sorry no digital camer but that will give you a idea when you look at the fuse box
Old Jun 10, 2003 | 04:17 PM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
cool thanks, im not sure how you listed them, did you just list third column from left side of panel ? im trying to figure out how you listed them
i just need third column, where most of the orange wires are coming out of backside of panel at
third fuse spot down from top- (looking at panel so that labeling of fuse spots is readable- not upside down)
thanks!
Old Jun 10, 2003 | 04:22 PM
Jproz1167's Avatar
tilt your fusebox down, the ecm/ign fuse will be in the top left corner
Old Jun 10, 2003 | 07:59 PM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
thanks! got them figured out, my courtesy fuse blade sockets are loose i noticed, wont hold fuse in place very well, will fall out easy, there is some white burn scorch marking around one of the courtesy light fuse slot terminals i noticed. ill have to replace that clip with a good one from a harness laying around
Ghettobird52
Jul 5, 2024 11:18 PM
db057
Aug 22, 2015 08:17 PM
Street Lethal
Aug 14, 2015 08:25 PM
stalkier
Aug 13, 2015 12:59 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
