Nordskog fuel pressure guage
Old Jun 29, 2003 | 07:45 PM
Blown87's Avatar
Car: 87 Z-28
Engine: 383 HSR w/supercharger, AFR heads
Transmission: 700r4 w/2500 stall
Axle/Gears: 3:73
I am planning on buying a Nordskog digital fuel pressure guage. I am installing this on a TPI. Has anyone done this? If so, where did you mount the sender? Any pictures would be much appreciated.
Old Jun 30, 2003 | 10:34 AM
Morley's Avatar
I am currently using a Cyberdine digital fuel pressure guage (same/same as the Nordskog) I mounted the sender on the firewall on the passenger side near the engine ground sprap. I used a large Adel clamp around the body of the sender and bolted to the firewall. Also, I used braided #4 line from the fuel rail to the sender and took the valve core out of the schrader valve.
92camaroJoe
Jul 29, 2023 07:57 PM
R3500
Aug 17, 2015 12:16 PM
wayshegoes
Aug 17, 2015 12:00 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
