Sensor/sending unit question
Old Jun 30, 2003 | 04:11 PM
XThree's Avatar
Car: 91 RS
Transmission: TH 700 R4
I have this sensor issue, when doing my hedders I went to remove a connector on a sensor and it crumbled in my hand due to heat exposure. I dont' know what sensor it is. Its no my knock sensor thats down below it, my engine temp sensor is on the drivers side near the first 2 plugs, my oil presure I think is right above my oil filter. I'm at work so I can't look now but I think my coolant temperature sensor is up front either near on the front of the intake manifold or by the water pump but I'm not positive4. What sensor is up by the back 2 plugs on the passenger side of the engine?
Old Jun 30, 2003 | 04:20 PM
Matto'85TA's Avatar
Car: 2001 Trans Am WS.6, 1985 Trans Am-RIP :,(
Engine: LS1, 305 TPI
Transmission: 4L60E, 700R-4
Fan control I think.
Old Jun 30, 2003 | 05:13 PM
cfabe's Avatar
Yep its your fan switch. Gotta replace it. Just to clear up teminology the thing in your drivers side head is the temperature sending unit, it controls what the temp gauge or temp light on the dash does. The thing on the front of the engine either in the intake or in the water neck is the coolant temp sensor, it is what tells the ecm what the temp is.
Old Jun 30, 2003 | 08:21 PM
XThree's Avatar
Car: 91 RS
Ah ok thanks..
Vintageracer
Jan 10, 2020 05:33 PM
jharrison5
Aug 19, 2015 05:53 PM
redmaroz
Aug 16, 2015 11:40 PM
Irocohio
Aug 12, 2015 08:03 AM
ZsTransAm
Aug 11, 2015 07:30 PM
