Help Me Figure Out The Last Few Wires Please
Old Jul 12, 2003 | 04:07 PM
david roush's Avatar
Car: 92'Camaro RS
Engine: a loud one
Transmission: bolted to the engine
After a tuned port swap i have a few wirs i can't figure out where they go. I am not sure if they are for the dual fan set up or what, since i am staying with the single fan set up. 1 st wire is GRAY, goes to pin out D-11 in the ECM (A/C Pressure fan switch) where dpes this wire connect to? a relay ? i dunno ...........2nd wire is DARK GREEN goes to pin out B-8 in the ECM (A/C Signal) i haven't a clue on that one either........... 3rd one is DARK GREEN/WHITE goes to pin out C-1 in the ECM, can't figure that one out either. And also i have a light blue wire that slices off of another wire, if you look in the picture at the gray connector in the lower left hand you'll see a light blue wire and two purple ones and a yellow ,it splices off that light blue wire i think it's for the heater. Also i can't find a wire to connect to my fan switch temp. sensor what am i missing here? Anyone that can help me, i'de appreciate it alot...thanks...Dave
TheJoeY88
Dec 31, 2016 07:30 PM
Thornburg
Aug 30, 2015 08:05 AM
litemupp
Southern California Area
Aug 23, 2015 10:09 PM
