Girl needs help Guys!!
Old Jul 27, 2003 | 09:19 PM
Jynxed86TransAm's Avatar
I know this sounds really stupid but I bought a digital multimeter recently and I lost the instructions and I have no idea how to use it . Im having some electrical problems in my car ... Any help would be greatly appreciated ...
Old Jul 28, 2003 | 02:20 AM
Odyssey's Avatar
And the fact that you're a girl is supposed to get people to answer your quicker or what ? If you don't know how to use a multimeter then you probably shouldnt be anywhere near anything electrical. LOL
Old Jul 28, 2003 | 04:59 AM
Somebody must not have got some last night . . .
Old Jul 28, 2003 | 06:18 AM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
To measure volts select the voltage scale. Some like the Fluke meters have 2 voltage scales indicated by a sine wave symbol for AC volts and one with 2 straight lines for DC. Or, you can simply look for a button that shifts the volts scale from AC to DC. In a car you will be working with 12 volts DC. When you are on the right scale the negative or usually black wire goes to a good chassis ground or to the negative battery terminal the positive or red probe goes to the device or wire you want to measure. To test your meter simply go across the 2 battery terminals and if set up correctly you should read 12 volts or so. To measure resistance put the meter into the ohms position and read across the device in question. Never use ohms where voltage is present, generally you will pop the fuse in the meter. Most meters will read current up to 10 amps, but require moving the positive probe to a different plug in the meter which is usually well marked. If it is a popular DVM you should be able to get an online owners manual from the vendors web site.
Old Jul 28, 2003 | 09:09 AM
MechCD's Avatar
Car: '92 Camaro RS, '93 Ranger
Engine: LO3, Vulcan
Transmission: 700R4, M5OD
Axle/Gears: 2.73, 3.45
I kind of agree..... I wouldn't start learning on a car electrical system, too many poorly marked things to play with.
Old Jul 28, 2003 | 09:59 AM
well thank you for your help Danno , I appreciate it.
Old Jul 28, 2003 | 10:55 AM
MechCD's Avatar
Engine: LO3, Vulcan
http://www.elexp.com/t_elec.htm
aaron7
Aug 17, 2016 06:02 PM
Eagle223usa
Sep 1, 2015 07:27 AM
Cleotiz
Aug 22, 2015 01:54 PM
PestilenceIV
Aug 20, 2015 03:32 PM
Street Lethal
Aug 14, 2015 08:25 PM
