Buying New Power Antenna and Radio, help please...
Old Jul 30, 2003 | 06:04 AM
phiberz's Avatar
Hi!
Need a new power antenna for my Trans AM GTA 350 -89.
The old one have been cut.
Anyone know where i can get a new one? original would be the best.
I also need to know if there are any new Car Radio that i can use together with the buttons on the steering wheel.
The old one are broken the display is dead but sound works etc.
BEST RGDS Phiberz
Old Jul 30, 2003 | 12:26 PM
Morley's Avatar
you are S.O.L. on getting a new antenna, I have been told that they are no longer being made. Hit the junkyards.
Old Aug 6, 2003 | 02:24 PM
badjuju342's Avatar
Car: '89 rs convertible
Engine: ls1
Axle/Gears: 3.73 posi
you can add an aftermarket antenna ,it's fairly simple. on the right side underdash you will find the power antenna relay.it is mounted to the the top side of the steel "rail" that lower dash bolts to. there are six wires,pink, orange,black,gray,white, and green.the pink is the trigger wire that radio power antenna trigger wire(usually solid blue on aftermarket radio),the orange is 12v battery feed,and the black is ground.an aftermarket anttenna will only need these 3 wires.be sure to use the new co-ax cable supplied with new antenna. the second part of your question is,yes, you can reuse your steering wheel controls, but there is a catch; you have to buy a radio with an infra red remote control . a company named P.A.C. makes a part that interfaces with the remote and the steering wheel controls. any more questions-feel free to email me
BRoss99
Aug 10, 2025 05:08 PM
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
IrocBuzz
Camaros Wanted
Nov 20, 2015 11:29 AM
Spd-Kilz
Interior Parts Wanted
Aug 15, 2015 12:12 PM
