Fuel Pump???
Old Aug 2, 2003 | 01:27 PM
fuzzdrummer311's Avatar
Car: 1992 Camaro RS
Engine: 3.1 L MPFI
Fuel Pump???
i have a 92 RS and every now and then it makes this little staccato, 1/4 second long whirr close to the back of the car. I'm guessing this is the fuel pump relay or something causing this. Am I right, and if so, what do I do? Thanks.
Old Aug 3, 2003 | 05:10 AM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
When the car is running you should hear a constant low pitch whining, that is the pump running. If the car has sat for a while and the fuel pressure has bled off it will come up and whine for 2 secs or so before you hit the start function of the key.
Old Aug 4, 2003 | 08:07 PM
Car: 1992 Camaro RS
Engine: 3.1 L MPFI
thanks but the only problem is the car has been off for three or four hours usually. I guess i should have mentioned that earlier.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
