power locks are shot
Old Aug 4, 2003 | 12:36 PM
Formula4Speed's Avatar
Car: 1990 Formula
Engine: 305 TBI (LO3)
Transmission: 5 speed manual
my best friend has a 91 RS and one day he said his power locks and his hatch release button just stopped working...Any ideas on what could be wrong? maybe a blown fuse?
Old Aug 6, 2003 | 11:37 AM
badjuju342's Avatar
Car: '89 rs convertible
Engine: ls1
Axle/Gears: 3.73 posi
yup, it's a fuse . check all fuses at panel under dash(especially dome,acc,ltr)this should solve problem
Old Aug 10, 2003 | 11:34 AM
Car: 1990 Formula
OKay he changed the acc fuse and it keeps blowing as soon as it goes in...any ideas?
Old Aug 11, 2003 | 01:38 AM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
i had a similar problem. I discovered a dime stuck in the cigarette lighter.
Old Aug 22, 2003 | 12:14 AM
83_Camaro_83's Avatar
Car: 1987 Z28
Engine: Tree Fiddy (modded)
Im having the same problem, but my headlights are also out, and my interior lights.......i need help too
:lala:
Old Aug 24, 2003 | 03:01 PM
eddie jr's Avatar
formula4speed - you definitely have a short to ground in the accesory circuit. The door lock switches are on this accesory circuit which explains why they aren't working. Does the fuse only blow when you try to use the door locks?? If so, trace the wiring from the door lock switches and look for craked wires. Also check the door lock relay behind the driver's side kick panel. A popular spot for pinched wires is in the area of the rubber tube that the wires pass through from the door into the body.
good luck.
83 Camaro - Your interior lights should be on that accesory circuit as well (as long all years are similar) but because your headlights are going as well which are on a different circuit, I would start by looking at the headlight/interior light switch on the dash as this is a common point between the two circuits. Follow the headlight wires back from the firewall as well as I had short along that line once that knocked out the headlights.
BRoss99
Aug 10, 2025 05:08 PM
IrocBuzz
Camaros Wanted
Nov 20, 2015 11:29 AM
sailtexas186548
Aug 24, 2015 10:11 PM
zayne0
Aug 24, 2015 07:22 PM
stalkier
Aug 21, 2015 01:54 AM
