wiring issues
Old Aug 15, 2003 | 12:37 PM
87350IROC's Avatar
Car: 87' IROC
wiring issues
Does anyone know where this wire connector goes? Its not for MAT sensor, distributor, or egr solinoid. It has a black wire and a pink with black stripe wire. I have tried on the Tech/General Engine and TPI board and I haven't found the correct location yet. Hopefully you guys can help me. BTW the wire is just on the driver side of distributor, but i suppose i could get it on the pass but i think it goes on the driver side.
JP
Old Aug 15, 2003 | 03:48 PM
Jproz1167's Avatar
Car: 1982 Trans Am & 1982 Corvette
Engine: L-98 with LO-3 induction. 350 CFI
Transmission: 5 speed and vette has 700r4
Axle/Gears: 373's in T/A .. vette unknown
VSS ...... I have a 87 trans am harness with a plug that looks like that for the VSS sensor same wire colors
Old Aug 15, 2003 | 07:57 PM
87350IROC's Avatar
Car: 87' IROC
hmmm... i thought vss was for firebirds only. Well in any case where is VSS in the engine bay? its worth a shot
Old Aug 16, 2003 | 05:52 AM
Jproz1167's Avatar
87
though your car doesnt have a electronic speedo, it does use a VSS, however it's cable driven and is on the back of your spedometer, camaros and firebird share the same wiring harnesses, therefore perhaps what you have found is the VSS wires that would go to a firebirds electronic speed sensor on the transmission.
Old Aug 16, 2003 | 07:16 AM
87350IROC's Avatar
Car: 87' IROC
so perhaps this plug doesn't go to anything?
Old Aug 16, 2003 | 10:04 PM
Morley's Avatar
Probably not, you'll find lots of plugs tucked away that don't go to anything, especially under the dash.
Old Aug 16, 2003 | 11:07 PM
87350IROC's Avatar
Car: 87' IROC
Ok, sounds good.
Thanks all
specialized
Jun 18, 2022 09:26 AM
Street Lethal
Apr 30, 2019 12:14 PM
Bryan F
Aug 18, 2015 02:28 PM
jbd1969
Aug 17, 2015 07:06 PM
Fronzizzle
Aug 17, 2015 02:52 PM
