Knock counts w/ a dummy sensor?
Old Aug 27, 2003 | 12:08 AM
r90camarors's Avatar
Car: '91 t-top RS; '91 hrdtp Z28
Engine: LO3;383tpi
Transmission: 700r4;very nice 700r4
Axle/Gears: 4.10 zt posi, 3.70 auburn
I've been using a dummy knock sensor because no matter where I set my base timing, the one in the block is picking up unheard of knock counts. I did a winaldl run and somehow managed to pick up knock counts even through the dummy sensor! Granted not near as many, but they were there. The dummy sensor is taped off as well.
Any ideas what could cause this or what could be causing my origional problem with the one in the block?
I swapped to the esc module and knock sensor recommended by gm for a zz3 w/ tbi swap-the closest I could get for the 383.
Also, I can't hear any pinging what so ever. But honestly, I don't like the idea of having to run a dummy sensor, especially when playing with the timing at the track. I also run a 160* stat (coolent doesn't see over 200* ever) and run the highest grade available here (92).
One other wierd note if anyone can comment on-I ran 104 unleaded at the track, and it actually slowed me down!?!?
Thank you in advance,
Roy
Old Aug 27, 2003 | 01:05 AM
nape's Avatar
Car: American Iron Firebird
Engine: The little 305 that could.
Transmission: Richmond T-10
Axle/Gears: Floater 9" - 3.64 gears
Re: Knock counts w/ a dummy sensor?
Roy
The higher the octane rating on fuel means it's a slower burn. More controlled if you want to call it that. Which ends up being great for cars that run high compression or high boost, but not so great for cars that have neither.
Old Aug 27, 2003 | 11:46 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Knock frequency is more dependant on bore than stroke, so a sensor for a 350 should be fine.
antman89iroc
36
Jan 31, 2016 08:42 AM
L98GTA87
Oct 19, 2015 10:43 PM
efiguy
Sep 27, 2015 01:30 PM
sreZ28
Carburetors
24
Sep 21, 2015 04:54 PM
FormulasOnly
Sep 10, 2015 09:07 PM
