Broke the damn speedo needle
Old Aug 30, 2003 | 07:07 PM
project j's Avatar
Car: black irocz
Engine: 305tpi
Ok so I feel like a dumbass i was cleaning a new instrument cluster and i was going to roll the odometer back to 00000, like an idiot i pryed to hardon the needle and the shaft the holds the needle broke. Any way to fix this or can i get it replaced.
Old Sep 1, 2003 | 01:21 PM
@ZZKKER's Avatar
Car: 86 iroc, 87 iroc, 89 iroc, 89 formula, 84 supra, 85 trans am
Engine: t\a motor 355 lt1 intake, t56,the works, 89 roc 427 sbc tt project
Transmission: to many to list
Axle/Gears: 9bolt 4:10 in the T/A
do you mean the plastic on the needle, or the metal shaft that the needle mount to? if the needle, you can glue it back together or use the one off of another cluster. if the shaft, then use the shaft from the 85 mph speedo im sure you have and swich them. just be sure to you a feeler gauge to measure the distance between the magnetic drive and the weight on the shaft, other wise you will need it recalibrated.
good luck
anthony
Bubbajones_ya
Oct 25, 2015 08:01 PM
wanext
Oct 6, 2015 12:18 AM
bjpotter
Oct 4, 2015 07:48 PM
sjorgens
Oct 1, 2015 07:54 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
