Fuel Pump
Old Sep 3, 2003 | 07:40 PM
karrlives's Avatar
Fuel Pump
I HAVE A 89 Trans am with a 305 I just rebuilt everything works fine except my fuel pump wont click on could there be a relay somewhere that i can change mayb a fuse?
And my Friend has a 82 with the same exact problem
would really appreaciate if someone out there can help us
his 82 has a Tpi which he just rebuilt him self and he is having the same problem as me?
Both cars have Vats but the secuirt light does not stay on and goes off. would really appreciate if someone can help us
karr
Old Sep 4, 2003 | 01:29 AM
Morley's Avatar
Fuel pump relay on the firewall on the driver side above the brake booster.
Old Sep 5, 2003 | 09:20 AM
karrlives's Avatar
I changed the relay
its like the fuel pump is not gettin power?
is there a fuse in the engine bay that i can check
or is my fuel pump gone?
KARR
Old Sep 5, 2003 | 11:08 AM
Morley's Avatar
Hook a volt meter to the wires for the pump at the relay and have someone turn the key on, you should get 12 volts. If you do get 12 volts your pump is shot.
Old Sep 5, 2003 | 11:24 AM
armac's Avatar
Car: 83 ta
check ofor voltage at the relay but also check to see if the oil pressure switch is hooked up and not staying open or shorted befor you replace the relay. to check the relay just use a nine volt battery and a few wires engerzing the relay with the 9 volt battery and see if you feel/hear the relay close. hook the battery up the the coil terminals pictured on the the relay casing
Old Sep 6, 2003 | 03:41 PM
karrlives's Avatar
the relay is good.
the power is all good
checked everything
can the pump be bad?
Old Sep 8, 2003 | 01:19 AM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Describe your problem in detail. Does the pump start running after you crank the engine for a while and the oil pressure goes up? Do you get a Code 54? You might want to check out this link to a post I found my problem in:
https://www.thirdgen.org/techbb2/sho...uel+pump+relay
My problem has been narrowed down to a defective ECM and that is screwing up all of my other sensors as well. Also, try unhooking your MAF sensor if you have one to see if that's the problem. Also, I know you have checked your wiring, but there are couple of simple things you can do to make sure it works.
1. Remove your F/P relay and check to see if the contacts are clean. Occasionally the contacts get somehow greased and refuse to make proper contact.
2. Connect a fused 12VDC source between terminals A (positive/black wire) and G (red/negative wire) of your ALDL (A is upper right and G is lower left). If the wiring, relay and pump are good, you will hear the pump running when you go to the back of the car and put your ear on the carpet behind the rear seats or if you remove the gas cap maybe? (I ain't sure- I put my ear flat on the carpet behind the rear seats to listen) If everything checks out and the problem is only with a cold start, the ECM is to blame. Talk about shelling out the $$$...
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
