Guage cluster guages dont work with lights on?
Old Sep 7, 2003 | 05:57 PM
Camarokid01's Avatar
I have an 86 sport coupe with the cluster from an IROC (245 speedo etc) During the day the guages work fine, but at night when I turn the headlights on, the Tach, oil pressure, volt guages all turn off ,and the right blinker light stays on, (all the guages on the right side) but if I turn the dimmer switch all the way down they come back on. Also during the day if I turn the right blinker on all of the guages stop working then come back on as the blinker blinks. I have taken the cluster out but have no found anything ovious. Does anyone have any idea of what might be the problem?
Thanks in advance
Old Sep 7, 2003 | 11:43 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
You'll need to remove the cluster again and check all the PC traces for breaks in the copper lines.
You can carefully solder a jumper wire across the break.
Pete
Old Sep 8, 2003 | 05:55 PM
thats what I looked for when I had it out, but there were no ovious breaks. I forget to say in my last post, that sometimes when I turn the lights on they will all work for 15 minutes sometimes? and then they will go dead almost like when they get hot.
Anymore ideas?
Old Sep 9, 2003 | 10:09 PM
onebinky's Avatar
I just fixed this exact problem on my car last night. It was a small hairline crack on one of the copper leads under the laminant, making it almost impossible to see. I fount it using the continuance feature on my meter, but you could probably do the same thing using a test light and a 9 volt battery if you don't have a meter. I soldered it up and it works perfect now.
Matt
Ghettobird52
Jul 5, 2024 11:18 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Jeremys87
Jul 14, 2022 09:08 PM
tnrednneck
Aug 13, 2015 08:57 AM
Omega
Aug 10, 2015 12:46 PM
