aftermarket tach wire to external dual coil.hlep!
Old Sep 7, 2003 | 08:22 PM
whytspeeddevil's Avatar
Car: 87 iroc-z ba boom!
Engine: V8 305 ( dont be fooled) =]
Transmission: TH-700R4 beefed up
hi...i just got an aftermarket tachometer from summit racing made by summit and its very simple...i got the ground on, the power wire on, and the shift light wire on, but now i have the tach wire that goes to the external dual coil that i have but i dont no which connector to splice into and each connector has a pink and yellow wire......so if anyone has a tpi ignition setup and knows what wire to use that would be helpful. the wiring diagram that they give you is very small and not specific. thank you to anyone that can help.:hail:
Old Sep 7, 2003 | 08:54 PM
Dave Y's Avatar
Car: 04 Xtreme Blazer
Engine: 4.3L V6
the wires should be pink/red and white, you tap into the white wire
Old Nov 19, 2003 | 02:58 PM
Tobias05's Avatar
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
gotta love the handy little search button, i had the same question...
Brandon
eightsixseven
Dec 16, 2024 01:50 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
mustangman65_79
Aug 7, 2015 09:41 PM
stalkier
Aug 7, 2015 04:49 AM
