Ground Wire Headaches
Old Sep 13, 2003 | 01:48 AM
91zzzeder's Avatar
Car: 91 Z28 All Original
Engine: LB9
91 Z28 LB9 auto 100kms
Recently I've been having weird things going on, my electronic speedo is off and then works for a while then off, my elrctric fan comes on when engine is cold, engine either idles fine, low or high.
From a previous post I gather it is probably a bad ground.
How many grounds are there? Where are they and which one is most likely the problem? Thanx
Old Sep 13, 2003 | 07:57 AM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
There is a ground from the block to the frame at the back near the dist, check the ground from the battery basically anything attached to the frame inspect, clean and redo. From your complaint don't overlook an intermittent internally with the ECM. You might try dropping it down and as you drive it have someone in the passenger(perferably with great legs) seat tap it with the handle of a screwdriver to see if you can generate the problem. Unfortunately with TG's there are a lot of little issues electrically related. Keep us posted.
Glowsock
Jul 24, 2025 03:15 PM
eightsixseven
Dec 16, 2024 01:50 PM
Jae992
Aug 27, 2015 09:07 AM
Armored91Camaro
Aug 25, 2015 12:01 PM
stalkier
Aug 21, 2015 01:54 AM
