Electric Choke Wiring ?
Old Sep 14, 2003 | 03:09 AM
nathan2003's Avatar
Car: Camaro
Hey, I have a 1991 RS... it did have Throttle Body Injection but I recently changed all that crap over to a carburetor with an electric choke... now I need to find a wire thats hot when the key is on but not when its off... obviously... but does anyone know of a good wire I could tap into that is really close to the carburetor... wanna keep wiring to a minimum... thank you for your help... peace out..
Vetter
Old Sep 15, 2003 | 03:24 PM
SHIFFS's Avatar
your probably stuck going from either the starter or the fuse box, if you go from the starter it will be kindof a pain, you should also fuse it. if you go from thefuse box you should be able to tap into a already fused circut, well if it doesent over load it. if it does just find direct 12v ignition and use a seperate fuse.
Ikes 91Z
Dec 9, 2015 03:49 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
stalkier
Aug 21, 2015 01:54 AM
Dialed_In
Aug 20, 2015 01:45 PM
86IROC112
Aug 17, 2015 02:00 PM
