need help wiring dual fans to toggle switches
Old Sep 16, 2003 | 10:27 PM
killer305's Avatar
Alright i have been searching for the last hour now, and cant find an answer to my question. my car came with a single fan, wich eventually burned out. what i want to do is install my new dual fans completely manual. i dont want the car to even try to turn them on. I want to wire them so i have 2 toggle switches both lighted and you have to turn on the first one, for the second to work, however i am nowhere an electrical engineer, acually i usually do not do any electrical work. i was hoping that someone can give me a link, show me a diagram, anything. thanks
Old Sep 20, 2003 | 11:54 PM
BA_TA_420's Avatar
pain in the *** my car came all like that. and i burn up a switch every week and my car fills with smoke every time it happens im evan running heavy duty 75 amp switches
Old Sep 21, 2003 | 05:01 AM
brobert's Avatar
I had the same problem,with the switches and stuff, untill i switched to thicker wire, its been fine since
Old Sep 24, 2003 | 05:07 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
What you need are 2 switches and 2 relays.
each switch controls one relay and each relay supplies power to each fan.
DO NOT HOOK THE FANS DIRECTLY TO A SWITCH!! You can cause a fire when the wires heat up and melt or the switches melt.
eightsixseven
Dec 16, 2024 01:50 PM
RazorN8
Jan 7, 2022 11:44 AM
Dialed_In
Aug 20, 2015 01:45 PM
355sbcTPI
Aug 19, 2015 04:38 PM
TA8487
Aug 16, 2015 12:21 PM
