Help wiring up stock ignition
Old Sep 24, 2003 | 12:12 AM
Camaro305to350's Avatar
My car currently has an MSD box and Im about certain it has gone bad. The car will sometimes cut out, and the only diagnosis Ive found is that it stops sparking. Ive checked and found spark to enter the box but none leaving it.
What must be done to disconnect the box and simply run the ignition without it. MSD says send them the box and they'll check it out and replace if it cant be repaired. But this is my daily driver so how can I bypass for the time being.
Any help is appreciated, thanks.
Old Sep 24, 2003 | 05:22 PM
83_1/2 L69's Avatar
Car: 83 Z-28 (Original owner)
Engine: 305 CC-carb
Transmission: Richmond 6-speed, Rear:3.73
Find MSD's install procedure, then do it backwards to un-install the box?
BRoss99
Aug 10, 2025 05:08 PM
Jeremys87
Jul 14, 2022 09:08 PM
Infested
May 22, 2018 11:56 PM
Caspar
Jun 19, 2016 11:19 PM
stalkier
Aug 7, 2015 04:49 AM
