Starting prblem
Old Sep 28, 2003 | 12:40 PM
89BlueIROCZ28's Avatar
Starting prblem
I installed a new headlight switch, after that the car decided not to start anymore. Now I get nothing, not even a click from the starter. The temp guage pegs out when i turn the key to the start posistion. I've checked to make sure no wires got unplugged under the dash during the install, checked battery voltage (12.45v). To me it seems like something is grounding out the circuit. I'm stuck Pulling my hair out.
Any clues on where to or what to look at or check woud be greatly appreciated. TIA
Old Sep 28, 2003 | 02:07 PM
MdFormula350's Avatar
well i would start by looking at the fuse block and make sure u didnt blow any fuses during the install.
that would be my guess right off hand.
Old Sep 28, 2003 | 06:53 PM
Allready did that but thanks for the input
Old Sep 28, 2003 | 09:43 PM
TPI86TA's Avatar
Car: 88 GTA
Id pull the headlight switch back out and try starting the car and see if that does the trick.
Old Sep 28, 2003 | 10:33 PM
onebinky's Avatar
Re: Starting prblem
Take your meter and measure voltage at the fat wire at the starter. It should read 12+. If it doesn't, trace the wire back. If it does, put the meter on the small guage purple wire and have someone turn the key. When the key is turned, it should read 12+. If it doesn't, trace the wire back to the key cyl. If it does read 12+, it is just a coincidence that it went bad when you did the switch. Your starter is bad
It could also be a bad ground for the starter solonoid, but it's much less likely.
Good luck,
Matt
Orr89RocZ
Apr 25, 2016 08:28 AM
Wade787b
Sep 29, 2015 01:15 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
92camaroJoe
Aug 13, 2015 06:07 AM
86Base
Aug 8, 2015 01:34 PM
