sending unit locations
Old Sep 30, 2003 | 12:46 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
I am curious as haynes doesnt do the best job of showing me...where are all the various sending units for a carb'd 350? ive got a bunch of Intellitronix guages and sending units that i need to hook up. i know the fuel pressure one..but what about:
-Oil Temperature
-Trans Temperature
-Oil Pressure
-Water Temperature
loo, do some of those even exist, or do i get the joy of drilling new holes
thanks in advance
Old Sep 30, 2003 | 10:59 PM
@ZZKKER's Avatar
Car: 86 iroc, 87 iroc, 89 iroc, 89 formula, 84 supra, 85 trans am
Engine: t\a motor 355 lt1 intake, t56,the works, 89 roc 427 sbc tt project
Transmission: to many to list
Axle/Gears: 9bolt 4:10 in the T/A
not used in 3rd gen or normal sbc-Oil Temperature
agian, not used in normal sbc or 3rd gen, first ime used in f-body would have been the lt1 automatic. -Trans Temperature
either down by the oil filter or up on top of the block by the distributor (depends on application)-Oil Pressure
either in the front of the intake, or in one of the heads.-Water Temperature
hope this helps you.
for the trans temp, put the sensor in the line going to the tranny cooler (inlet line)
oil temp- in the oil cooler line, or one of the spots the oil pressure switch does not use (you only need one because you have a carbed motor, computer FI used the sender down by the oil filter).
good luck
anthony
Old Sep 30, 2003 | 11:01 PM
@ZZKKER's Avatar
or you can put the tranny temp sensor in the side of the trans pan, but the cooler inlet line would be better.
good luck
Old Sep 30, 2003 | 11:11 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
sweet, thanks guys! thats just the info i needed.
86CamaroDan
Sep 29, 2015 10:08 PM
Gunsbee
Sep 7, 2015 07:10 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
tonys91rs
Sep 2, 2015 07:07 PM
