stock tach, mind of its own?? (91 z28)
Old Sep 30, 2003 | 08:21 AM
91n99fbodies's Avatar
Car: 91z28
Engine: LB9 305TPI
if you wind out 1st gear the tach will jump over to 7k or higher, i KNOW that the stock 305 isnt going to rev that high without floating the valves, at first I had thought that maybe it was reading twice the rpm's, maybe somebody wired up a tach and had fudged up the wiring, but the stock harness is unmolested. Are the stock tachometers very inaccurate or do I have a freak of a car being able to rev a stock 305 to 7000rpm???
Old Sep 30, 2003 | 10:53 PM
@ZZKKER's Avatar
Car: 86 iroc, 87 iroc, 89 iroc, 89 formula, 84 supra, 85 trans am
Engine: t\a motor 355 lt1 intake, t56,the works, 89 roc 427 sbc tt project
Transmission: to many to list
Axle/Gears: 9bolt 4:10 in the T/A
different tachs are off a diff amount. sounds like yours it way out of calibration. did you happen to drop it at any point in time, as that is bad. you may need to have it recalibrated.
but on a diff note, most oem tachs are off a little (mine is off a 500 rpm) but it sounds like yours it really off.
good luck
anthony
Old Oct 1, 2003 | 12:12 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
MSD ignition will throw the tach WAY off unless you run the signal wire from the factory tach to the tach lead on the side of the MSD box.
I said screw it and bought an Autometer !
Jeremys87
Jul 14, 2022 09:08 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Orr89RocZ
Apr 25, 2016 08:28 AM
mustangman65_79
Aug 7, 2015 09:41 PM
stalkier
Aug 7, 2015 04:49 AM
