oil gauge?
Old Oct 17, 2003 | 11:42 PM
icebird_1981's Avatar
oil gauge?
hey guy i got a prob with my oil gauge on my camaro when i turn the car on it fly right to the top well just a bit over and stays like that. then soon as i shut it off it goes down very slow till it hit the bottom. i checked the wire and its fine, is it some sort of sensor or is my gauge messed or is this for real
Old Oct 18, 2003 | 09:19 PM
Matto'85TA's Avatar
Car: 2001 Trans Am WS.6, 1985 Trans Am-RIP :,(
Engine: LS1, 305 TPI
Transmission: 4L60E, 700R-4
IIRC, theres a oil pressure sensor near the back of the engine near the distributor.
I'm not sure exactly what it looks like. I think its cylindrical with some wiring coming off. I hear its a pain to change Someone else help me out here so I dont lead him in the wrong direction.
Hope this helps some.
Matt
Old Oct 19, 2003 | 05:52 PM
MaxxMitchell's Avatar
Car: 87 Firebird
Engine: 5.3 76mm
Transmission: Rossler TH400, PTC converter
Axle/Gears: Strange 12bolt, 3.08s
He is right its the sending unit, there are two, they are both right around the oil filter. I got a v-6 but it should be close even if its an 8, on mine i had two, one that was small that had a single wire connection, then a larger more like a filter looking thing, with a one wire connection and a metal spade comming out of the sensor. Both sensors will run around $15 each, and when changing them luckally you wont have to worry about too much oil comming out, because the pump wont be running.
BTW the larger filter looking one broke on me, there is a spot to grab it by the spade, then there is another area closer to the block you will probly have to get under the car to change both to make it easyer on your self.
Sorry i couldnt find any pictures to show you exactly where it is, but its on the driver side of the block, lower half, v-6ers have it mounted right around the oil filter.
Bubbajones_ya
Jul 6, 2024 08:32 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
TrevinE
Sep 14, 2015 03:20 PM
86IROC112
Sep 11, 2015 04:04 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
