Vats killing injectors?
Old Oct 20, 2003 | 08:06 PM
Liqued212's Avatar
Car: 91 Camaro RS
Engine: 305 Modded
Transmission: 700R4 B&M blue clutches
Could it be possible for vats causing my car not to spray fuel? When i go to start my car i have to wiggle my key to get vats to read the key cause it is wore down .. but my car wont spray fuel unless I prime it then it sarts and sprays and i read a post saying somthin bout vats doing this.. is this possible?
Old Oct 20, 2003 | 10:57 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Yes this is possible. The VATS tells the computer to operate the starter and fuel injectors when it reads the proper code resistance in the key. The fuel system is primed when you turn the key to the on position. By the way, did you get the e-mail I send you with all the information concerning the VATS?
The Trickster!!!!!!!!!!
Old Oct 21, 2003 | 08:36 AM
Liqued212's Avatar
Car: 91 Camaro RS
Engine: 305 Modded
yeah I got it thanx just dont got adobe yet .. so i cant open it but what resistant is key code 12?
Old Oct 21, 2003 | 08:56 AM
385LT1's Avatar
to remove vats, ground the yellow and black wire on the starter relay. simply snip the wire, leaving enough to add a crimp connector with a ring end , and bolt it to a suitable ground.
*The vats module grounds the starter relay, after it recognizes the correct key.
(Note: color is from a 94 Z28, may or may not be different)
Old Oct 21, 2003 | 04:02 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Hello liqued212,
The resistance on key code 12 is 6040.
The Trickster!!!!!!!!!!!!!
Old Oct 22, 2003 | 08:54 AM
Liqued212's Avatar
Car: 91 Camaro RS
Engine: 305 Modded
hey thanx for the info.. for some reason my car went through temper and didnt want to work then yesterday i tore the dash out the fuel pump out and replaced it all even though i didnt need too.. you know how women are you have o buy them things all the time.. :P
KCG
Jun 24, 2020 04:33 AM
gta892000
Aug 11, 2019 11:16 AM
sahlomonic
Sep 20, 2015 07:15 PM
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
