'91 Speedo/cluster question
Old Oct 21, 2003 | 04:09 PM
r90camarors's Avatar
Car: '91 t-top RS; '91 hrdtp Z28
Engine: LO3;383tpi
Transmission: 700r4;very nice 700r4
Axle/Gears: 4.10 zt posi, 3.70 auburn
My speedo stopped working in my 110mph guage cluster. Pretty sure the motor went bad as the needle had a lot of resistance when I took the cluster out.
Anyways, I figured I'd upgrade to a 145mph, and after install, I notice the tach is way off. So I replace it with my old tach out of the old cluster, and it does the same thing!
So my theory is that the 145mph cluster has an electrical problem as far as the tach is concerned.
So I guess the question is:
If I simply pull the speedo out of the 145mph cluster and put it in my old 110mph cluster, will it read right? Or will it read as if I had a 110mph cluster in there? I'm not sure where exactly it is calibrated at....I would assume the cluster's electronics, though it may be in the motor it's self. Any help would be appreciated. Thank you in advance
Old Oct 22, 2003 | 09:13 AM
Liqued212's Avatar
Car: 91 Camaro RS
Engine: 305 Modded
Transmission: 700R4 B&M blue clutches
what kind of car is this in ? and is the speedo elect. or mech. ?
Old Oct 22, 2003 | 12:27 PM
Engine: LO3;383tpi
90 RS, electronic speedo
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
