Est
Old Oct 23, 2003 | 11:44 AM
Girlie85TA's Avatar
Car: 85 Trans Am
Engine: TPI 305
Transmission: 700 R4
Est
Ok, I thought my car's timing had been screwed with, but then I checked it and it's probably more perfect than I could have gotten it. So my question is, can I disconnect the same wire that I did to check the timing and still drive the car, at least as far as up the little hill into my garage? The only check engine code I get is for the EST and it's running so bad now that I can't even get it back into the garage. Do I run the risk of ruining something else if I run it with that wire disconnected?
Old Oct 23, 2003 | 08:25 PM
3gc's Avatar
3gc
Car: Z28
I think you'll be fine driving it a little bit with the est wire disconnected. I forgot to reconnect it once after i checked timing and i got an ses light. I just reconnected it and it went away in a few seconds.
db057
Apr 28, 2019 07:45 AM
L98GTA87
Oct 19, 2015 10:43 PM
3rdgenkindagal
Sep 13, 2015 02:02 PM
pacoelrapido
Sep 11, 2015 02:41 PM
1992Vortec
Aug 31, 2015 08:05 PM
