pLz HeLP!!!!!
Old Nov 2, 2003 | 11:33 PM
Tobias1989RS's Avatar
Car: 1989 Chevy Camaro RS
Engine: 2.8L
pLz HeLP!!!!!
I just bought a $180 CD Player for my camaro. After hooking it up, i noticed when i turn the volume level to about 25 or so, my CD player would just shut off for about 5 seconds then turn back on. At the same time every light in the car will start to dim or flicker. Also, whenever i hit the brake, it does the same thing. What would cause this? Any help would be appriciated. :hail:
Old Nov 3, 2003 | 04:39 AM
Daishi's Avatar
Car: 1988 Camaro IROC
Axle/Gears: 3.27 9 bolt posi (non 1le)
My best guess is you prob blew a fuse. When I installed my entire stereo I accidently blew 4, thats right 4 fuses, just by letting a few wires touch each other, effecting everything from dome light to dimer, to high beams, taillights..
Its an easy thing to check at least, even if im wrong I only killed a minute of ur life
Old Nov 3, 2003 | 12:52 PM
Thirtybird's Avatar
Car: 91 Z28/99 WS6/02 WS6
Engine: All 350's :)
Transmission: 700R4 & 2 Tremec T56's
I'd say its drawing more power than the alternator can cope with (or a weak battery) and its dipping below 12v. The stereo then shuts off because it doesn't have enough juice. Once it shuts off, the voltage goes back over 12v and comes back on. This also explains why your lights are dimming.
Old Nov 3, 2003 | 02:45 PM
Engine: 2.8L
Well, i checked all the fuses, and they seemed to be fine. So it probably is the alternator. I might go buy one today, if that doesnt work, i really have no idea what else it would be. There might be some wires that ARE really touching each other that i wont be able to reach, cuz when i bought the car, almost all the wires were hacked....
Old Nov 3, 2003 | 04:48 PM
Engine: 2.8L
Does anyone have a diagram of a camaro fuse box? I just noticed that a couple fuses burnt BADLY that it started melting the box itself. Now i cant read what fuse is what.....
inferno15
Aug 29, 2015 01:48 AM
BitchinCamaro
Nov 28, 2001 01:51 PM
Amrish
Nov 9, 2001 11:33 AM
Amrish
Jul 16, 2001 02:16 PM
